Archive Button
DavidN
Has thanked: 16 times
Been thanked: 11 times
Archive Button
Post by DavidN »
Good work so far with the updates. Thank you.
I have two suggestions and will post on separate threads.
It would be great to have an archive button in the menu bar on mail. This would allow the user to set a path for their archive email and then simply select the email and quickly send to a folder of choice. Would be a big time saver.
Thank you
Has thanked: 1412 times
Been thanked: 984 times
Re: Archice Button
Thanks, that's a good suggestion, noted.
Bernd1
Re: Archive Button
Post by Bernd1 »
An archive button is one of my most used buttons. Please implement it. Thank you.
DavidN wrote: Sat Jul 04, 2020 1:24 pm Good work so far with the updates. Thank you.
Thank you
