EPIM Android Back button not working as expected for notes
- Laurent C.
- Has thanked: 4 times
- Been thanked: 12 times
Re: EPIM Android Back button not working as expected for notes
This is absolutely not a duplicate : please read
EPIM Pro + EPIM Android (AEPIM) / W10 Pro 64 bits FR + Office 2019 Pro Plus
- Laurent C.
Not corrected in Android after release of PC EPIM 9.6.1
- Has thanked: 1424 times
- Been thanked: 990 times
How could anything be corrected on Android after release of EPIM on another platform?
- Laurent C.
I perfectly understand that, but I presume that if EPIM PC is updating a lot of time, the EPIM Android should not be abandoned : no fixing since July 2020
Have you had a chance to check the recently released 5.8 version?
- Laurent C.
The recent Google version today is 5.7.4 ...
- Laurent C.
Android EPIM 5.8
It works - all works and translation is correct
Except : when I modify a note, use Cancel/Annuler to stop, but click inside the note a 2nd time, and use the Android back button, then it forces a saving again while displaying Note saved/Note enregistrée
Regards
Regards
Unable to reproduce this. Please record a small video showing the issue.
- Laurent C.
Hi
I can’t download the video in Attachments : ERROR / File too large: 20210113_111454.mp4
It is written : If you wish to attach one or more files enter the details below. You may also attach files by dragging and dropping them in the message box. Maximum filesize per attachment: 10 MiB.
However, my film is 3 MB only, and yet above the ERROR !?
Regards
Regards
Please post it to some online file storage like Google Drive and share the download link.
- Laurent C.
You're right : I was lucky the very 1st time, as it is not so easy to reproduce, because it happens 1 time out of 5 trials...
Here the video
I try at the beginning of this video without success with my first note while testing
In the end, it happens with "Note enregistrée" after "Annuler" and Android "Back button"
Thanks, will check this out and fix.
- Laurent C.
Cela semble corriger pour EssentialPIM 9.8 + EssentialPIM for Android 5.8.1 = vous confirmez ?
