Hi there,
I use EPIMcloud for uploading some of my files. So I can use those on any device.
I would like to have a backup of that section of EPIMcloud. Is there any tool or whatever, to do such a backup or is the only possibility to download files?
HOW TO backup EPIMcloud?
- Has thanked: 1447 times
- Been thanked: 1006 times
Re: HOW TO backup EPIMcloud?
I believe there should be such a tool, which is able to work via WebDAV. You can use our compiled demo example of the WebDAV component for getting access to the files (https://www.sync-components.com/downloa ... V_demo.zip), although there's no special backup options in it.
