Hello, it looks like I have deleted a task folder in Epim but when synchronizing it in outlook, it refuses to delete that folder which it's considered as default.
I looked at the logs but there is no indication of what outlook expects to find (the folde name).
Any ideas ho to solve this?
Thnak you
Your request can't be completed. A default task folder can't be deleted
- Has thanked: 1447 times
- Been thanked: 1006 times
Re: Your request can't be completed. A default task folder can't be deleted
Yes, please forward me the log file, will check out what's wrong.
- Has thanked: 1 time
Hello Admin, thank you so much.
I have attached the latest outlook sync log
- OutlookComSync_2021_03_08_19_20_41.zip
- (7.97 KiB) Downloaded 226 times
Thanks for the log! Please click on File->Database Mangement, then select Outlook.com under the "Clear synchronization data" section and click on the Clear button. That should help.
