<FRENCH> translation
- Been thanked: 1 time
Re: <FRENCH> translation
Hi there, looks like that "Éléments supprimés" is now displayed as only "Éléments"
- Golfy
- Has thanked: 14 times
- Been thanked: 26 times
From my tests with 8.03, it's OK. Which version and FAI are you using ?
Please check with language file french.lng, on line 6000
6000=Boite de Réception|Boite d'envoi|Éléments envoyés|Éléments supprimés|Brouillons|Modèles|Indésirables
- 2018-08-18 22_11_13-Window.png (5.36 KiB) Viewed 4258 times
Looks like it did not update to 8.03 I have 02. Updates and text OK...Thanks
- Golfy
french translation isn't dead
Here is the v8.52 french translation file.
I'm feeling a bit old when looking on the time I've spent in translating EPIM.
- French.lng
- (108.19 KiB) Downloaded 242 times
- Golfy
Hi here
it's been a long time (and mine is very busy) but as nobody took the relay, I've tried to translate many sentences. There is a important mistake I've removed, about shortkeys menu in options (they're having the same before) :
So I recommend you to use this translated file, even if not all fields have been translated. Version 9.6.1
Thanks,
David
Thanks,
David
- French .lng
- update 7:30pm
- (112.12 KiB) Downloaded 213 times
