EPIM Android - Impossible to add a contact from Phone app
Laurent C.
Has thanked: 4 times
Been thanked: 12 times
Post by Laurent C. »
Hi
Seems you forget to register EPIM Android in apps authorized to add contact after a call using recent calls...
Regards
EPIM Pro + EPIM Android (AEPIM) / W10 Pro 64 bits FR + Office 2019 Pro Plus
Re: EPIM Android - Impossible to add a contact from Phone app
It should be EPIM Android's account, not the app itself.
Laurent C.
Hi
No, it's not
If I install another app for managing contacts, the app resisters itself to be able to create new called numbers in Android contacts
It's not the case with EPIM ; and only EPIM is concerned so far... :?
Regards
Laurent C.
Hi, what is the status since EPIM 9.6.1 please ?
