Hello, EPIM BIZ PRO, 9.5.x
Module Notes > try to enter time stamp (would be a lovely feature!)
And here I get:
See the last two: it is the same.
1. So I would recommend inverting one of them:
16-12-2020 14:02
Then it would make all perfect sense.
2. The best would be, in my opinion, to make it
16-12-2020 | 14:01
to simply separate day and time visually. That would be great, I think.
Solved. One of the time stamp options doubled
- Has thanked: 16 times
- Been thanked: 40 times
- Has thanked: 1079 times
- Been thanked: 743 times
Re: Tiny bug: one of the time stamp options doubled
These values depend on your regional settings in Windows and are different for various world regions.
Got it, thanks. Hence, if double thing is not an issue anymore, would you consider somehow separating hour and the date?
These are system values and we cannot influence them, unfortunately. We're only able to add our own or custom ones, although not really sure if that's needed.
