Ho una rubrica con diversi gruppi
Se creo una nuova mail ed inizio ad inserire il nome di una persona che ho in rubrica, non mi escono le opzioni possibili con le prime lettere che inserisco.
Altre volte invece sì...
Perché??? Devo prima andare a cercare l'indirizzo mail della persona a cui devo inviare la mail e poi inserirlo di volta in volta?
Spero di essermi spiegato
Grazie per l'aiuto
Destinatario nuova mail
- Has thanked: 1429 times
- Been thanked: 993 times
Re: Destinatario nuova mail
It shouldn't matter when you start typing a person's name or his email address in a From field, for instance. Hope I was able to understand your question correctly. Thanks!
Some times, when i receive an email by someone i have saved in my contacts, i see received by and the email address and not the name! Why? Thank You
Could you please attach couple of screenshots to your next post to demonstrate the issue?
I have both "Bob Green" and "Sam Red" saved in my contact list.
Why in my incoming mail i receive mails by them but if writes me Bob Green i see the name i saved, but if writes me Sam Red i see his email address???
I have this problem with many contacts but only with essential pim and not with other pim programs
It doesn't matter whether a contact is saved in the contacts list, we get contents of the From field for a particular message from that message headers. It means that "Sam Red" chose to enter his name as an email address in his email app.
But in thunderbird, gmail, yahoo mail (for example), if i save a contact, and i receive a mail by him, i will see the name i saved and not what he decided.
Why here is it not possible?
Another person might also be using that email address for sending correspondence out. In that case which name does EPIM need to show?
.... it seems absurd...
If I receive an email for the first time, i see the sender's email address. But then, if i save the contact with a name and a surname etc... Why can't i see that name!?!?!?!
It is like a phone mumber in a smartphone!!!!
The first time someone calls me, i see the phone number! But then, if i save it with a name, the next time that person calls me i see the name i saved!!!
It is so strange that you don't understand the problem and that you have this problem because with other software it is normal.
I told to my headquarters to buy this program but now i m in a hard place.
Will see what we can do here, thanks for the suggestion.
