Sincronizzazione epim cloud
GabrieleCerbini
Post by GabrieleCerbini »
Buongiorno a tutti,
ho Essential Pim pro su un computer e ho acquistato Epim cloud. Qualcuno sa dirmi come sincronizzare le due cose in modo da vedere in cloud quello che viene modificato/aggiunto sull'altro computer? Scusate ma sono un novizio di Essential Pim.
Grazie
Re: Sincronizzazione epim cloud
You mean you'd wish to login to epim cloud? If so, you can do it here: cloud.essentialpim.com. Thanks!
GabrieleCerbini
No it's not that. I would need to have all the data on my PC downloaded on my epim cloud, but I don't know how to do that.
I see, you need to click on File->EPIM Cloud->Sign In in EPIM in order to start using the service.
GabrieleCerbini
Will I lose all my previous data/files in EPIM if I do that?
Absolutely not, quite contrary - they will be moved to the Cloud and you will be able to always access them from any other PC.
