iCal import issues (Czech special characters)
xtermit
Post by xtermit »
I have a problem with special characters when importing an iCal Calender in Czech, presumably because of wrong encoding.
I cannot change the encoding since it is imported from a public google calendar -https://www.google.com/calendar/ical/cz ... /basic.ics
It imports as "Den slovanských věrozvěstů Cyrila a Metoděje" and "Den upálení mistra Jana Husa".
While it should be "Den slovanských věrozvěstů Cyrila a Metoděje" and "Den upálení­ mistra Jana Husa".
Thank you very much for any help.
Best,
Martin
Has thanked: 1115 times
Been thanked: 774 times
Re: iCal import issues (Czech special characters)
Confirm this problem, will be addressed in the next update. Thanks!
xtermit
Post by xtermit »
Awesome, thanks a lot!
