一直出现乱码框,怎么设置都不行
- Has thanked: 1426 times
- Been thanked: 993 times
Re: 一直出现乱码框,怎么设置都不行
Please purchase the official license of EssentialPIM Pro. Do not use illegal/cracked/hacked versions and all should be good.
Re: 一直出现乱码框,怎么设置都不行
Please send me a PM here in the forum with the order id number and your existing license key. Will check it out and issue a new key for you, if needed. The error described in the OP only happens when a pirated version of EPIM is being used...
