Search & Replace
a8907433
Been thanked: 152 times
Search & Replace
Post by a8907433 »
EPIM portable pro 9.0
Notes Module: From an an App on my phone I exported my financial data as xls, opened with Excel, marked and copied all fields, pastetd it into a note. Now I have a big (table??- I´m not able to make table lines visible in "table properties), >400 rows. Now I want to make "Miete" (German for "rent") more visible, for example bold & red. It occurs approx. 40 times in 400 rows. So, how to do it fast?
manual..... :-(
search > next: When typing "Miete" in the field in the upper right corner, I block EPIM for a long time, it is searching all the database it seems....
CTRL F, Find & replace: this works, but I have to do from "Miete" to bext "Miete", click bold and color....
It would be much easyer and faster, if "Search % replace" would be able to find "Miete" and replace it with "Miete"
