No agenda synchronization on Ipad OS 13
I use Epim on my computer and on my Ipad. Since the upgrade on my Ipad to Ipad OS 13, it's impossible for Epim to synchronize properly my datas. Epim only synchronizes my contacts... and not my agenda.
I have a daily intensive use of the agenda for my job and this synchronization problem is very detrimental for my workflow...
If someone knows how to solve this problem (all my technical details are in my signature), I thank him by advance
EssentialPIM Pro 9 - Windows 10 (1903 - 64 bits) - Ipad (IpadOS 13.2.2) with EssentialPIM for IOS 2.8.3.1
Re: No agenda synchronization on Ipad OS 13
it works on my tests. To troubleshoot, enable extended logging in Tools-> Options-> Synchronization, perform iPad synchronization and then get log for the synchronization using Tools-> Options-> Synchronization-> Browse and send it to epimsupport@... with a link to this forum topic.
Thank you Max for your answer, I'm gonna do that !
Hallo !
I have the sme Problem after Update to EssentialPIM Pro 8.6.1 and Update on iPad and iPhone to iPadOS 13 and iOS 13. I miss a few events and dates on the iPad and iPhone. In EssentialPIM contains them but after sync they are not on the iPad and iPhone. I will describe this in a own post. Furthermore i Wang to make a log from Sync. In the past the Sync works very well.
Regards,
Andreas
Regards,
Andreas
