I'm using Essential PIM Pro V5.6.2 password program on Android.
Is there a way to export the entire set of passwords decrypted to a text CSV file?
I couldn't find anything in the forum about it.
Thanks!
Export decrypted text?
- Has thanked: 1418 times
Re: Export decrypted text?
Thre's a way. You'd first need to synchronize your password entries with Windows EPIM and then export them into a decrypted CSV file from there.
Oh, so I have to install the windows version? I can't export from the Android version?
Is there a trial copy I can install just long enough to retrieve the passwords?
Thanks!
Thanks!
You cannot export to a CSV file from the Android version. There's a 30-days free trial period for the Pro Windows version. Thanks!
