Current version EssentialPIM Pro 5.6.2 on Android version 6
Issue#1 Colors not correctly save
Kindly refer to attachment. You can see that text colors not turn out correct after reopening note
Issue#2 Missing sentences
when using text colors or maybe bullets/numbering, i would have occasionally loss of sentences
Unfortunately I'm unable to replicate this since it was happening randomly
appreciate if your support , thanks!
p.s: auto-hyperlinking is irritating, i wish that was someway to disable this feature
Text colors incorrect & randomly missing sentences
Re: Text colors incorrect & randomly missing sentences
I'm unable to reproduce the problem shown on the screenshots. Were there any synchronizations involved on your side?
if u mean Google sync, no that's not enabled
in dark theme, black text over yellow background always revert to white text. in light theme, always revert to black text
about randomly missing line/sentences, i only notice when i start using rich text feature
I should have switched to the dark theme first, thanks for pointing that out. Color reverting happens automatically to increase text visibility. This is by design. Thanks.
you tell me if white or black text on light blue gives better text visibility? besides your dropdown menu shows black text on light blue not White
I see your point, will do something about it in the new versions.
