I sync my contacts with nextcloud (version 14). However, the photos can not be displayed in nextcloud
EPIM is 8.14 Pro
Synchronization with nextcloud - Contact photo is not visible
Re: Synchronization with nextcloud - Contact photo is not visible
EPIM does not support Nextclud per se. Using which protocol do you synchronize Contacts?
Would you have an account on Nextcloud that we could test against? If that's a bug on our side, we may fix it.
Sorry, my nextcloud server is only accessible on the LAN.
Maybe that helps: Here a 5 days test account can be created:
https://ploi.io/nextcloud
lg
lg
Hi Max.
I tried again.
This time with a new EPIM version including a new DB. In Nextcloud (latest version) I created a new user. I selected owncloud as the synchronization profile. The synchronization runs normally. All contact details have arrived in nextcloud. Data is also stored in the field of the contact picture. When I try to download the image in nextcloud, I receive a file with the name "20191225T091527Z508330.vcf". This is an approximately 8 KB file that cannot be displayed as an image.
Something is wrong with the synchronization
regards graf
I tried again.
regards graf
It looks like Nextcloud gives you VCF format, which can not contain image (specifications: https://en.wikipedia.org/wiki/VCard)
You might want to read Nextcloud documentation if it is possible to download images.
I did a test with Thunderbird: Install the CardBook addon and set up synchronization with Nextcloud (CardDAV / vCard v4).
Photo in CardBook added and start the synchronization with nextcloud : the photo is correctly displayed in Nextcloud. Then a synchronization with EPIM started (one way to nextcloud): The photo in nextcloud was again overwritten with the vcf file.
To me, that sounds like a bug in EPIM
regards graf
regards graf
