EssentialPIM Pro 4.5 Release Candidate 2!
Dear EPIM users!
Today we are announcing EssentialPIM Pro 4.5 Release Candidate 2.
We are getting closer to official release. Probably the next build will be the Release.
Feel free to try and post your impressions on the forum.
Downloads:
EssentialPIM Free Desktop: http://www.essentialpim.com/download/be ... lPIM45.exe
EssentialPIM Free Portable: http://www.essentialpim.com/download/be ... Port45.zip
EssentialPIM Pro Desktop: http://www.essentialpim.com/download/be ... MPro45.exe
EssentialPIM Pro Prortable: http://www.essentialpim.com/download/be ... Port45.zip
EPIM Sync: http://www.essentialpim.com/download/be ... Sync45.exe
Fixed:
  • Mail empty accounts problem
    To Do Notes issue
    To Do Reminder window issue
    Email issues
Improved:
  • Attachment Manager shortcut added
    Hyperlinking
AlJones
Re: EssentialPIM Pro 4.5 Release Candidate 2!
Post by AlJones »
Request access to the beta section please.
AlJones wrote:Request access to the beta section please.
Currently Beta testing is over. This a public release, so you do not need access to beta section.
streethawk
Post by streethawk »
I have the portable version and any menues in the pulldownbar are invisible or not shows completly.
regards Streethawk
mc44it
Post by mc44it »
HI
I installed the beta 4.5 rc 2.
I can not run the sync with google. The response message is: HTTP/1.1.403 FORBIDDEN !
If I sync my contacts only the completion message but does not record anything
Suggestions?
(translated by google)
Ho installato la beta 4.5 rc 2.
Non riesco a far funzionare la sincronizzazione con google. Il messaggio di risposta è: HTTP/1.1.403 FORBIDDEN
Se sincronizzo solo i contatti ho il messaggio di completamento ma non registra niente
Suggerimenti?
streethawk wrote:Hello,
regards Streethawk
Make sure you update the language file.
mc44it wrote:HI
Suggestions?
The "HTTP/1.1.403 FORBIDDEN" message means login/password is incorrect.
ianmonster
Post by ianmonster »
When I tried running this, all message rules from the old database were deleted.
ianmonster wrote:When I tried running this, all message rules from the old database were deleted.
Please make separate topics. It is not clear what you tried to run.
