Epim not loading
Epim not loading
Postby TerryRogers » Wed Jan 17, 2007 9:32 am
I have a problem, that when I double click the epim pro portable icon the program appears to load (Appears in task manager, hard disk light flashes a lot) but n o gui appears.
Any one else had this issue? Any idea how to resolve?
The program will run in compatibilty mode (Win98) but with several errors.
Terry
TerryRogers
Moderator
Postby TerryRogers » Wed Jan 17, 2007 4:44 pm
Just for any one else who has the same problem, discovered that this was down to a service called "iolo DMV Service" that is installed with System Mechanic 7.
After disabled the service the app worked fine..
Terry
TerryRogers
Moderator
Postby Max » Wed Jan 17, 2007 7:18 pm
Thanks for letting us know the outcome!
EPIM Knowledgebase: http://www.essentialpim.com/ky/index.ph ... se&_a=view
Ever wanted to make Online Backups the right way? http://www.s3backupsystem.com/
What is "iolo DMV Service"?
Postby tobius » Sat Jan 20, 2007 1:44 am
I can not open Epim, I also run System Mechanic #7 but I can't find any reference to your quoted problem, on my system (XP) or on the Iolo actual site.
This "iolo DMV Service" - what is it and how can I find it?
Was wondering if that is why I can't open mine. Was on vacation, hubby playing with my system, he updated System Mech to the latest version - got back, now Epim Pro won't open.
Thanks for any help,
Tob
tobius
Re: What is "iolo DMV Service"?
Postby Max » Sat Jan 20, 2007 12:08 pm
tobius wrote:I can not open Epim, I also run System Mechanic #7 but I can't find any reference to your quoted problem, on my system (XP) or on the Iolo actual site.
Tob
That's a known Mecanic's problem. They interfere with our licensing system. Vendors of Sy Mechanic know about it, not sure when they going to fix it.
Postby tobius » Sat Jan 20, 2007 1:00 pm
That is great news - I will hound them, maybe one more hound will do the trick
THank you so much,
Tob
tobius
Postby Max » Sat Jan 20, 2007 3:42 pm
tobius wrote:That is great news - I will hound them, maybe one more hound will do the trick
THank you so much,
Tob
Yep. You can tell them it is a case with Armadillo from Silicon Realms. Pretty many software vendors use it and now all of a sudden new version of System Mechanic prevents Armadillo from loading.
Return to Support
Who is online
Users browsing this forum: No registered users and 2 guests
cron
